tell me about itkillablue240 wrote:the colder it is the harder it is to start
mine would take FOREVER to crank up and start when its cold (i run 15w-50, changed thickness didnt change a thing). checked everything and cleaned everything but the maf, still the same thing. went and took out the maf, cleaned the sensor, unscrew the top section and there was a lot of rustish (don know if thats word) stuff on there. cleaned it up, BAM, cold idle, starts right up. when it was warm it would start right away, no loss in power, holds boost (7psi) and accerelate(sp) like a champ. problem only occured during cold starts.S13FASTBACKSR wrote:kamikaze did you have any other symptoms besides just not starting when cold? i highly doubt that the maf, cts and iacv would cause ONLY a cold start and absolutely nothing else..its obvious his oil is waaaaaay to thick for the winter
have you checked the cts when its cold AND hot? both of them have to be ok. the rpm dip can be your bov but can also be the tps. when you rev, the rpm will go up, and come back down fast until around 1500rpm where itll slowly go down to neutral. that is your tps working. so the rpm dip MIGHT be your tps. check the voltage on that.are you sure those mafs that you used was in good condition? if you have a check engine light, then you should check those first before doing anythingkillablue240 wrote:interesting... but i took an ohm meter to the cts and tried three different mafs, and all the same results.compression is good, i checked all wiring and it looks good, only other things to mention are that when coming to a stop in neutral the rpms dip to like 400 then go back up to about 800, and codes for CAS and knock sensor.
honestly, i didnt know that maf effects cold starts either. thats why i checked the maf last lol. my maf was fine in the voltage but when i checked resistance it was a little off. you have to check both resistance and voltage, and see if both of them are in range.S13FASTBACKSR wrote:the idle dropping to low after putting the car in neutral is more than likely either your bov spring not being tight enough or the bov needing to be recirculated..thats cool how the maf was the problem for cold starts ive never heard of that before very interesting..and your getting codes for your cas and knock sensor? do you hear any knock? i would pull the knock sensor and see if it looks corroded and pull the cas and see if its burnt out or anything if you see anything suspicous at all
thats cool man, you learn somethin new everyday..just like the tps causing the idle to drop..to me it would be if the tps was the problem it would cause misfiring or richness or leanness too..but you never know..how he describes the idle dropping is it dropping fast to 400rpm..thats why i think its the bov spring not being tight enough or it needs to be recirculated because the maf reads that air and then tells the ecu to tell the injectors to put more fuel in but once the air is let out by the bov the a/f ratio is wrong and the idle drops because too much fuel is put inkamikazestorm420 wrote:honestly, i didnt know that maf effects cold starts either. thats why i checked the maf last lol. my maf was fine in the voltage but when i checked resistance it was a little off. you have to check both resistance and voltage, and see if both of them are in range.
if he is venting his bov to the atmosphere then he should fix that first and then check the tps. because like you said, venting the bov is known to do thatS13FASTBACKSR wrote:
