The Clutch Damper...
devlmaycry
Car: 95 Nissan 240sx S14.5
So, I finally got tired of a clutch pedal that engaged the clutch like a 1/4" off the floor and bypassed my clutch damper. The problem I was running into was that based on how hot it was outside if I adjusted the pedal to release at a comfortble spot it would slip bad once the car/trans got hot, then when I adjusted it again to where it wasn't slipping then it released way to close to the floor.
I did some searching and found out that people with aftermarket clutches have had similar problems, some not even disengaging the clutch at all, and decided to try this cheap 30min fix. I've only driven around town and romped on it on some side roads to see if the clutch slipped (it hasn't) and am very happy.
So, for those who haven't done this basic mod I highly recommend it.
TheRealNap0le0n
Car: 1998 q45
cool story brah
Ender_Zero
Car: '03 Base Z, '91 S13 Coupe
This and a stainless clutch line are a good combo for those looking for better clutch feel and precision of release.
