The Clunk in the steering?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Urq
Car: 82 Ur Quattro & 07 Black Versa SL CVT.
I remember seeing a post about clunks in the steering but cant find it now?Did anyone figure out just what it is for sure Rack, Strut Bearings or what not as mine just started this clunking when turning hard Left or Right and it sounds like springs to me not being set right??I have a 07 VERSA with 8500miles on it.
blindsnyper
Car: 2007 versa
Urq wrote: I have a 07 VERSA with 8500miles on it.
well theres your problem, you dont drive it enough
Urq
Most of the trips I take are to the store drop off and pick up the kids and about 4 trips to Vegas each year.
BGDG
Car: Nissan Versa
I have the same problem CLUNKING AND KNOCKING NOISE IN THE FRONT END (front suspension) OF THE VEHICLE AND I FELT IT IN THE STEERING WHEEL. The noise was coming from passenger side. All these issues are acting when the vehicle is driving slowly and making right turn going up on the driveway or down on the driveway. I filled a complaint to Office of Defects Investigation (ODI), an office within the National Highway Traffic Safety Administration (NHTSA). If you have the same problem even without accident I'm going to recommend to file a complaint too.
Guys, I found the same complaint all over the different forums and it looks like this is a manufacture defect.
PLEASE TAKE A MINUTE FROM YOUR TIME AND FILL OUT THIS COMPLAINT FORM.
You can find a link below:
http://www-odi.nhtsa.dot.gov/ivoq/
http://www.nhtsa.gov/cars/problems
kvg
Car: '08 Nissan Versa Sport
'89 BMW 325i coupe
sounds like a pain in the a**.
good luck finding the problem. :bang :bang
Knightro2
Car: 2008 Nissan Versa SL
Had this problem on my '08 V. I would get 2 clunks at low speed turning right. I could reproduce it by driving slow and turning the wheel right 1 1/2 turns. It turned out to be the steering joint assembly. Nissan replaced it and it has been good for almost 2 years so far.
carlos15
Car: 09 versa sedan 1.8l
window tint
white footwell lighting
1993 miata
ebay exhaust
greddy turbo kit
ebay interfooler
megasqrtui
ohh that happens in my 09 v when i tunr around slowly or turn in any way slowly you can hear a clunk its kinda weird should i take it to the dealer? :gotme
ME18VERSA
Car: 09 nissan versa
89 5.0 mustang
i would love to take mine to the dealer but i knw they will tell me that they wont do anything about it because i have lowered my car.. does any one know about how much this part costs
gekko668
I had the same problem a few year back. First they replaced the upper steering column and it stops the clunking for a few months then it came back. They replaced the lower steering column and now the problem is gone. Hope it helps
NODES
Car: 2007 Nissan Versa SL (Blue)
gekko668 wrote:I had the same problem a few year back. First they replaced the upper steering column and it stops the clunking for a few months then it came back. They replaced the lower steering column and now the problem is gone. Hope it helps
mine has either disappeared or i got so use to it that I do no feel or hear it any longer.
Return to “Versa Technical Discussions”
