the only way to mill off a considerable amount and not need an adjustable gear is to take off enough to roll the chain over an entire link (wayyy to much ive already pondered the idea). You would then have way to much slack in the one side of the chain (half master link can make this up, but i dont think its the greatest idea). I think you should stray away from this on the ka, it is not worth it. You can get new aftermarket ka24e pistons for very very cheap. You can check the prices at your local auto parts dealers and such, or if you would like, i can get you a set. The one thing you should look out for when buying aftermarket pistons is the proper size. Many aftermarket pistons are not made exactly to oem spec (compression height, proper dish) the bore, ring, and pin sizes they usually get correct. Get some quotes from various places, then email me i can most likely beat their prices and you can be assured the pistons will be high quality and oem spec.
oh and about making an adjustable gear. You would have to enlarge the notch in the gear, and place a shim to take up the space. easy in theory, but really a waste of time as said before because milling is not the proper way to gain compression. Putting ka24e pistons in is to easy not to do.
[email protected]
