The car's at Lovefab... pics inside!
QuickerThanU
Car: 98,95,94,89 Nissan 240sx
Would i really need a 60mm wastegate for 500hp? What do i need to do to preorder the mani for a t3 gt35r setup?
Tinker219
Car: 771whp Acura NSX
Next week will be devoted to building RB2XDET manifolds. If you want your manifold in that batch, you had better get on the horn before Wednesday to reserve the current crackhead pricing! We will take any form of payment except Discover Card.
I prefer the largest wastegate that you can possibly fit because boost-creep SUCKS! I also put forth a ton of effort into tayloring each wastegate entry port to entice aiflow into the wastegate to further help prevent boost creep. I'll have some pictures of this later today; as far as I know, I'm the only one to go this far to prevent boost creep.
I wanted to snap some pictures of a T3 collector that I completed for a customer's manifold that has already been purchased, but I was so excited about these pictures that I kinda forgot.
Also, I found the RB26 gaskets that I had ordered several years ago so I'm getting the head flanges retooled to work on any RB motor.
I think I will fixture the 60mm wastegate location and dumptube. The 44mm wastegate is simply a smaller version and will DEFINATELY fit in the 60mm WG location. The only thing that will differ will be the dumptube which I will NOT fixture at this point. If I get requests from people who are actually ordering, I may build a 44mm setup.
rotorimp
Car: 02 Xterra, 60 IH Metro
I definitely humped the screen a bit
2 things
run custom lines over to the other side for your powersteering--un less you like fire.
Get a good heat shield for the brake master or you will have a real mess there tooCheck out what I did. the heat shield goes completely around the master and the gold film reflect 78% of the heat back.
Tinker219
Thanks for the tips! I designed the manifold so that you can snake the PS reservoir return line between the 1 and 2 runners. Obviously it will have to be hardline through the runners, and heat-shielded. There should be room to go elsewhere with the lines if desired.
6mm bolt weld-on bosses that will be welded to the downpipe and probably certain runners of the manifold so that heat shielding can bolt to the downpipe and manifold. The effect is decidedly OEM in effect.
rotorimp
Very nice--I would to see some pictures
disrupt
Car: 2006 TRD Tacoma, 1992 240sx coupe
what kind of welder did you use? I assume tig but i guess my question is how many amp power source it had? water cooled? and also how thick your piping is? thanks
Tinker219
I welded this particular setup with a Miller Syncrowave 250. I also have a Lincoln Precision Tig 275 that is regularly used, and a Lincoln Squarewave 175 that is the backup welder incase one of the first two breaks(it happens).
We use Schedule 40, 304 stainless steel for all of the runners in our manifolds.
gawdzilla
Car: none
Tinker219 wrote:Also, I found the RB26 gaskets that I had ordered several years ago so I'm getting the head flanges retooled to work on any RB motor.
Cody i sent my old pair of rb26 manifolds to you through r33gts-t (i think thats his screen name). You should have them, no?
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
Wow if only I had money to spend like that I would get it in a heart beat!!
gawdzilla, do you have aim or anything? I would like to ask you a few questions. Thanks.
Tinker219
gawdzilla wrote:Cody i sent my old pair of rb26 manifolds to you through r33gts-t (i think thats his screen name). You should have them, no?
I have no recollection of that screen name nor do I have any knowledge of any incoming RB26 manifolds?
Though I have only been viewing this forum for around two weeks now, maybe something was overlooked. PM me if this surprises you, we will figure something out, we don't need to air dirty laundry publicly unless its the last resort.
On a more positive note, we've sold a couple of manifolds now, with only two days left to get the deal of the year! So far so good. I have 10 RB head flanges being made as we speak, it would be killer to get all of these out there
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
I guess my manifold will have to wait on lay-a-way.
Sucks being poor
gawdzilla
Car: none
Tinker219 wrote:I have no recollection of that screen name nor do I have any knowledge of any incoming RB26 manifolds?
Hmm, it was the guy who started the original Lovefab manifold thread: zerothread/226962 .. Daniel Fatell? Anyway, not trying to cause trouble, I just shipped my old manifolds to him which aren't really worth anything. he said he'd give them to you cuz i thought it would help if you were making a 25/26 dual flange with both bolt patterns. no big deal
Tinker219
Oh ok, I vaguely remember Daniel talking about this. I do not have them and I assume Daniel does, so contact Daniel to get them returned if you need them back.
If I extend the sale of another week, will there be anymore takers?
QuickerThanU
Try posting on "the bad place" aka zilvia. I think most of nico is cheap arses.
Kung Fu Grip
Car: 93' fastback
QuickerThanU wrote: Try posting on "the bad place" aka zilvia. I think most of nico is cheap arses.
Not really if they have a RB swap.
lucky7
Car: 97 RB25 S14
more like 'broke arses'.
im having a revilation. i think im just going to do an internally gated turd turbo. i dont have the energy to dump another 4k into a turbo set up. not yet anyways. lol.
240wootie
Car: 1989 rb20 coupe, 2002 WRX
lucky7 wrote:more like 'broke arses'.
i agree... RB's make already broke college kids uhh.. more broke...
to the OP, that thing is b-e-a-u-t-i-f-u-l! keep us posted!!
Tinker219
Hey guys,
I will have to completely redesign the manifold to fit the AC compressor. If there is a ton of interest, I may build an AC manifold and the price will reflect this. If-not, than AC won't fit, sorry. It was hard enough to get the damn AC compressor to fit in the engine bay anyway!
$1400.00 Pricing is good through December 1st. Merry Xmas!
QuickerThanU
e.t.a on the manis? Update?
until240
Car: '95 240sx
cody has a non-a/c compatible rb25 manifold with a t3 flange for sale. it was originally mine, but when i decided i wanted to keep my a/c, he graciously agreed to make me a new manifold, and i would only pay the price difference. someone please buy the manifold so i don't feel so bad anymore!
eh?
I'll give ya 600 bucks! I mean I'll try to get around not having a/c
until240
Car: '95 240sx
lol. when i talked to cody today, he still wanted the $1400 for it. but if he really wants to get rid of it...maybe he'll cut you a deal?
QuickerThanU
Wow... Lucky you. Wish i could get an update on my t4...
QuickerThanU
egatz man... wtf?? Thought i would have my manifold like a month ago
until240
Car: '95 240sx
yeah...me too. apparently he's really busy with other stuff. and he hasn't started on the a/c manifold yet...
QuickerThanU
Well hell... I didnt even sign up for the ac. I was one of the first to pay for the original design w/ the t4.......sigh........
Tinker219
James' T4 has been done for almost a month. I finally found enough time to get on here and post. Call me up! I need to confirm your shipping address before I ship it out.
The AC manifolds will be started early next week. The winter blast that we are currently going through froze up some water pipes that burst in my home. I haven't been able to get much done trying to fix that mess.
And yes, we have a T3, 60mm gated manifold on the shelf ready to go for those that don't care about AC. I'll honor the $1400.00 sale price. From now on, they are $1800.00 and $2000.00 for AC versions. If we get a batch of 5 guys together that want the same exact manifold, I may do another GB.
QuickerThanU
Wow. Good **** man. Was just wonderin about updates but now i know and appreciate it. Ill prolly hitcha up tomorrow before i go to work. Thanks for everything.
74260zt
Car: rb26powered early 74 260z car
$2,000 ?? Thats quite a price hike....
BoostFab
Car: S13cp, S13fb, S14z
yikes
