gsxrjjordan »
https://forums.nicoclub.com/gsxrjjordan-u40199.html
Thu Feb 22, 2007 9:51 pm
I mostly hang out on Z ilvia, but figured I'd lurk over here for the night. Most of the info here is good: I know the US-made stuff isn't bad (I'm a JWT and BC fan), but I've chosen to build my head with Tomei hardware, more for resale/rep than performance difference, although whenever a professional drift team needs a crate motor, they call Tomei...
Anyhow, Tomei makes a couple different sets of springs, Type A is just a thicker spring, developed to work with their "street" cams (Poncams), and Type B is a double spring rate set with Ti retainers (retails for $1k, just for springs and retainers!) for their Procams. I've got Type A's with stock retainers (they're fine).
As far as cams, 256/264/272 are HKS sizes, that most of the industry has copied. The info about "staggered" sizes above is good stuff, and yes people run staggered sizes to help spool their big turbos sooner - that's about it. Anything above a 2871 .86 should be running a size larger on the exhaust side if you ever plan to street/autox/drift the car. Running full 272s is NOT fun, and none of the professional drivers do it. 256's are a huge improvement from stock, dont get suckered into buying cams that are too big for your application - and as stated above, you buy cams AFTER you've decided which turbo to run and what kind of power to make. Also, Tomei cams don't use quite as high a lift on their cams as HKS Step 2/JWT C series/BC, so keep that in mind (more lift with the same duration is more aggressive).
About cam gears - Tomei makes gears, as so a couple other companies, but to be honest, there's not a whole lot of power to be made by using adj. cam gears on SR20s I've found. The people that are running adjustable gears have already maxed out their current tunes (like 400whp off a GT2871 .64 with 256/256 cams), and are searching for that last 15hp or so. Waste of money at the stage that most people (including myself) are at.
Make sure whenever you're building a head to have a machine shop that knows what they're doing check everything, deck the head, and for God's sake, get a good head gasket - Tomei/HKS/Apexi/Power Enterprise, in either 86.5mm or 87mm.
Hopefully people that actually build heads will come into this thread and either add on or respond to my post ~
