Latest dyno figures from a friend of mine in the UK... you might know the car (old Norris Design's S13) now owned by a friend of mine, Richie.
Simon from ND said the car should make 540rwhp back before Richie bought the car. Since then they made a few changes to make even more power. The car was never dyno tested until today.
511.5 bhp @7770rpm at the wheels388.3lb/ft @6124rpm at the wheels
613.8bhp @7770 rpm at the flywheel466lb/ft @6124rpm at the flywheel
Those are the numbers it punched out. Why so low you ask? Because it was running on the engine management's BASE MAP! For all of you guys that know anything about tuning that means this car EASILY has another 50whp if not more. They are switching to a Motec system and should have numbers out later on.
So there you go
