navysnail »
https://forums.nicoclub.com/navysnail-u13430.html
Wed Feb 22, 2006 6:21 pm
I helped trigger via AIM with his problem, I am posting some of the conclusions so others may search in the future:
starter is getting battery voltage when they key is turned, not starting. He will try to push start the car which will determine if the starter only is bad or if the engine also has another problem such as not getting spark or fuel. Starter is new, worked for a day before failing. Car would not start after working on the heater (replacing control panel with a known good unit). This could be a coincidence or an electrical problem could be present, attempted push start will determine the answer to this.
