Are you looking for this one?SirSilvia wrote:as for that foot light you got there, where can I find one?
Cruise On/Off switches are right below headlight up/down switch. I think you should just find cruise control on/off switches to block off the holes and you can put two blank panels instead of a coin holder. You can modify those blank panels for the switch. I thought about that location for the power folding mirror switch, but the switch was too big.S133P3R wrote:isnt the cruise controll on the steering wheel? i ono... i did the mod and used the worthless coin holder on the right of the steering column on the dash... cut out the plastic with a dremel and flipped it to cover the switch like a hood...
hmmm, maybe i do... it doesnt work regardless, maybe ill wire my "stealth mode" swith in there instead....hbpignosePA wrote:you should have cruise control on the dash too... right hand side by the rear defogger
Yes, power folding AND heated mirrors.Ekinchheng wrote:What the fu*k!! The jdm one has heated mirrors!??? I never knew than, too bad winter is almost over.
Yeah, it's a different trim. Heated mirrors are even hard to find in Japan. I don't have heated mirrors. It's just the switch. We don't need them here in TX.Ekinchheng wrote:Where you get it at? I tried ebay and pandagarage has one but it doesn't have heated mirrors?? Maybe its a different model?
ag240 wrote:
Obviously quality work.ag240 wrote:Personally, i find those big switches a pain, i just get the small stem switches and drill one hole. I dont like cuttin exact squares to fit them, so i just get the easier to install switches:
