The best oil filter, and where can i get a good cam
AAPman23
Car: 1992 Maxima SE VE30DE
hello everybody!!!Does anyone know what the best kind of oil filter to use on a nissan v6? I don't know if there's a curtain brand made specificly for nissans or not.And does anyone know where I can get good stage 1 cam shafts?
see ya!
THT
Car: 96 Legacy L AWD 5spd wagon, 04 M45
OEM or Mobil 1 filter
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
oil filters don't differ much. i get wix because they're cheap and good. for cams i'd go comp cam or jwt.
i just looked both up and none makes a cam for you...sorry.
Modified by allensteiner at 8:20 PM 6/18/2008
i guess you could call them and see if they can make you a custom cam = $$$
Modified by allensteiner at 8:25 PM 6/18/2008
johnnyd6404
Car: 2004 G35 Coupe 6MT 2k2 Maxima SE(sold) 2005 Altima 2.5S
I use the K&N its nice cuz its a wrench off type very easy to remove and replace not to pricey either usually around $15
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
allensteiner wrote:oil filters don't differ much.
Actually, that's very inaccurate. Filters absolutely differ. Construction type, materials, filter element (material and surface area) vary greatly.
However, you are right in saying that Wix is a good choice.
Another good choice (and a cheap choice) is WalMart's Supertech. They're manufactured by Champion labs who makes the best filters out there (in my opinion, based on a good deal of research) Including Mobil1. They're similar to Mobil1 filters, but have a slightly lower-quality filter element. Construction and other materials are still top-notch like the Mobil1, though.I use SuperTech filters in my cars.
Fram filters are horrible. Construction and materials are bottom-of-the-barrel. Very poor.
I know I post this a lot lately, but search the Q45 forum for "oil filter." You'll find some good discussion and links to lots of good filter comparison studies (many with photos). Lots of info to be gleaned.
THT
I was going to say, "cut open a Fram and a Mobil filter then tell me there isn't a difference"
allensteiner
i'm sorry fellas that i wasn't specific as to fram...i didn't think anyone was using any of their crap.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
My mechanic says to use oem
He says you may burn up your engine on anythingelse because if the OEM gets stopped up the enginecan still get oil through a filter bypass
CPS
There are lots of options on oil filters other than the dealer. I personally recommend WIX and Purolator Pure One, which are two of the best filters you can buy. I can tell you that a Purolator and a Nissan OEM 15208-9E000 are virtually identical when you cut them open.
Nissan does not make their own oil filters either. Do you know why Nissan part numbers change from time to time? Because Nissan changes their vendors. The 15208-31U00 and the 15208-9E000 are interchangeable, but they are two totally different filters. Same thing for the 65F00 and the current 65F0C. As a matter of fact, no car manufacturer makes their own filters to my knowledge. It's just somebody elses stuff with the manufacturers name stamped on it.
sweet3rdgen
Car: 1990 maxima se
Napa gold
