ScottJackson »
https://forums.nicoclub.com/scottjackson-u14976.html
Thu Mar 15, 2007 7:21 am
I dunno exactly what the expert was meaning with that, but on the Ford forums they say to not use Dexron/Mercon with transmissions like the C6 which originally used Type F fluid. However, if the trans has been rebuilt in the last 15 years, the clutches should have been changed and most if not all the rebuild clutches/bands are compatible with Dexron so it's fine to use that fluid in that case.
