Pwnin O'Brien »
https://forums.nicoclub.com/pwnin-o-brien-u136941.html
Tue Sep 01, 2009 8:14 am
Also, in the first and second picture I can see that your driver side headlamp is installed improperly. The small piece of trim directly under the headlamp sits lower than it should. I had this same exact problem with my aftermarket lamps and I can tell you (through trial and error) how to fix that.
As you know there are four bolts which hold the headlamp assembly to the vehicle, one on top, two on the side, and one on the bottom. Well the bottom bolt should be held on by a small metal bracket which is bolted to the headlamp assembly. That bracket is adjustable. By moving that bracket in and out, you will tilt the headlamp assembly up and down. Currently your headlamp is tilted too far down, thus the trim which hangs low. You need to push the metal bracket out (towards the engine) and this will lift the headlamp up enough for the trim piece to sit right.
You will want to re-adjust both lamps so that they are even and both trim pieces are level.
Of course, I could be completely wrong and the trim may just be seated wrong against the grille.
