The bad starter works!!!
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Ok so my car was just clicking and clicking 5-9 trys and it would start so i thought to my self starters going bad right...Ok so i bought a used on from a member...And i just went to autozone and got them both tested and the one i pulled off my car worked perfect...What the hell!!! Maybe a bad ground was what i was thinking...Anyone??? Oh im running a small oddesy battery if that matters..
SpeedRacer1
Car: 1990 240SX, G35
Usually when the starter just clicks the battery is on the way out or has low voltage.
9240sx
New oddesey battery though....Maybe i sould get it recharged
S13FASTBACKSR
Car: '92 Fastback SR powered
ya possibly a bad ground like you said ...loose probably ..did it seem to come off easy when you took the starter off?
9240sx
No everything was tight..But ill be putting a new ground on it anyways..Just in case ya know..Im starting to think its a weak battery..It was harder to start the longer i would go without starting her up...If i drove the car the next day after i starter her,It would start up just fine..First try.But i never drive this car...For sometimes months at a time.
