Well yesterday it was time for the 500 mile checkup on my KA-T car. I figured I would go through as much of the engine I could without pulling it all apart and see how things are doing.
Turns out, lots of things are breaking! Yay!
Nothing really really serious, just all kinds of little things seem to be suffering from bad placement, melting from heat, or separating under stress. The first thing I noticed is that one of my IC couplers is beginning to rip:
This was particularly distressing to me because I decided to go the extra mile and spend big money on quality silicone from
http://www.turbohoses.com. ...And yet here I am, 500 miles later, and the thing is ripping already and leaking out some of my precious boost. However I called turbohoses and talked to Brian over there, he is shipping 3 days from cali to CT a replacement for free. Very nice guys over there, I must say.
I also noticed that my turbo is rubbing somewhat against the underside of my hood, to the point where it actually wore down the turbo a bit.
It doesn’t rub at all with just the hood down while the engine is off, but the engine does torque quite a bit under boost so I'm thinking thats when it rubs. No big deal, this is one of those "self solving" problems haha... it will wear down and cease to become a problem! I will keep an eye on it though. ...And yes I realise the compressor is dirty! This is what happens when you get your hands caked in grease and then start leaning on all kinds of things in the engine bay...
Also one of my all-important vacuum lines going to the wastegate has melted:
That’s not good at all. Easy fix, but I'm glad I caught it. That is one place where you definitely do NOT want to mess with vacuum pressure.
Another issue I noted is that the cover on the underside of the hood was burning. I knew this for a while, it was smoking just a teeny bit when it got hot enough, so I decided to fix it:
Dont mess with me.
Another problem that I encountered was heat-warped and welded turbo bolts! I decided to wrap the downpipe with heat wrap because of all these things melting, and while doing it I managed to break one of the turbo to manifold flange bolts:
Awesome. So this means my car is now not drivable yet again and I must pull the whole turbo/dp/hoses off in order to drill and retap the freakin flange for some studs this time. Hopefully I can get it done by the weekend so I can get some solid driving time in... Also note how nasty that ETD manifold is looking after just 500 miles of heat cycles. Ah well.
Other things I found wrong but didnt take pics because this thread is getting too long:-My PCV breather filter thing on the valve cover fell off and is lost forever. I dont know where it is, must've fallen off while driving, never to be seen again. Guess I should do better than APC this time eh? -Wire loom around some wires near the downpipe is beginning to deform from the heat... guess I need to extend and move them out of the way. Freakin turbos are way too hot!-It has rained 80% of the time since my car has been done.
Welp thats just about it for now! All kinds of things wrong but nothing really big so I suppose that is good news. If for nothing else let this serve as a reminder to people: you need to constantly check these engines over for tiny problems! I found a bunch of things that could have led to huge failures if left unchecked.... so do yourself a favor and give your car the once over every once in a while eh?
News on how many vettes/mustangs/civic DXes I smoke is coming, this weekend.
