tfs1975 »
https://forums.nicoclub.com/tfs1975-u201323.html
Wed May 21, 2014 1:40 pm
Hi All,
I am not new to the NICO forum but new to the 300ZX section. Previous daily driver was an M35 and this forum helped me out many times. I recently got my hands on what seems/seemed to be a pretty nice black 91 TT, 5 spd. Not a swap. I would add pics but I am not a rocket scientist and can’t figure out how. Just getting old I guess. Got a good deal on some 350z wheels and had to put them on already. They look great. I would consider the mileage to be low in regards to the age at 114k. Two owner car and it looks to be mostly original with good paint and good interior. Picked it up in Palestine, TX and towed it back to Austin. It's been in my garage for a few months now and I need to get under the hood and get this thing on the road. I have wanted a 300zx since I was 18. At that time I was approved for pretty much the same car but insurance costs and being practical lead me to forego the purchase. I ended up getting a DSM car (Eagle Talon) and working that. Even though it was an AWD rocket, it never did take the place of the 300ZX I always wanted. I have gone through this forum pretty good and have read the "everything to know about your Z” section as well as a lot of posts and DIY's. I will attempt to do most if not all the work myself. I have a few questions as well as a few concerns. I have done a pretty good inspection of the car and have a parts list that is needed to get back to 100%. Big jobs needed are the 120k mile timing belt change (new bolt kit needed) and the driver’s side valve cover gasket (all valve cover gaskets will be changed at that time). Of course with those two jobs, the plugs and oil will be changed as well. Here is the parts list that I will be ordering shortly. Recommendations are welcome for any parts or supplier you feel is good. I have looked at Z1 and CZP.
-Adjustable Tension Rods
-Front Adjustable Camber Upper Control Arms
-Plenum Gasket
-New Radiator
-Exhaust Valve cover seal
-Valve cover gaskets (as referenced above)
-Silicone PCV hose kit with PCV valves
-Solid bronze shifter bushings
-Rear outer Ball joints (could just go with the HICAS delete)
-Adjustable rear upper control arms
-Power steering rack boot
-120k mile timing belt kit (as referenced above)
All seals seem to be good. After initial inspection, I thought that this would get me to 100% or what I think is 100% as a starting point. At which point I would start doing all the tests stated in the "everything you need to know section". OK...sorry for the long drawn out explanation....this leads me to my ultimate question and concern. I had noticed that the radiator is shot. Shot in the sense that the car had sat for a few years and the fluid is rusty. I would prefer to replace and that is why the radiator is on the parts list. Did an initial flush just to get it out on the road and see what issues I could find. Once I returned, I notice some gurgling coming from the coolant overflow canister and upon filling it up, on the next trip it was gurgling and coolant was leaking out. Needless to say that I am extremely concerned that this could be a bad head gasket is an understatement. I know that these cars shouldn’t sit and if they do there should not be water in the coolant system as it may corrode from the inside out. Coolant still looks OK, no smoke from the tailpipes, nothing strange under the oil cap and no temperature issues. I am wondering if there is an air pocket (don't think this is the case), a bad heater core, bad thermostat or possibly the dreaded head gasket. So the question is (finally) do I go ahead and do the valve cover gaskets and timing belt change that will include the new radiator and water pump and see if that takes care of the issue or do I test for the possibility of the head gasket being bad? I can't really do all the tests stated in “the everything you should know” section in the current condition. Is there a way to determine that it is not the head gasket before doing all this other stuff? Just don't want to rip everything apart just to have to do it again at a bigger level. Appreciate any and all suggestions. Thank you.
