Milo (San Antonio) »
https://forums.nicoclub.com/milo-san-antonio-u61519.html
Wed Jul 11, 2007 11:16 am
Agree w/ Zwicked.
Antifreeze has anti-freezing properties. It keeps water from becoming ice, in a simple sense.
Antifreeze/coolant has anti-freezing properties and a small amount of coolant properties.
Water is a great reducer of heat, hence the main reason it is used as a large majority in almost every coolant system. I would agree with Zwicket in going with distilled or demineralized water (about $.89 a gallon) instead of normal tap water as water from tap can have minerals that can help increase rust deposit/PH deposits/etc.
Coolant additives (Purple Ice, Waterwetter, etc) are just coolants thats main purspose is to reduce temps in the coolant system.
Time of year makes a difference on what you run, or at least it should. Everyone seems to have their own opinions on what do use and the difference in amounts.
