So I've got this roll bar I put in to brace the chassis after the C-pillars were removed. There's a cross-bar at the bottom that's level with the rear of the vehicle, with the substructure for the deck running from the back of the vehicle all the way to this lower cross-bar.
So this left an area under the cross-bar that I could fit a couple 6x9s. I whipped up a bracket/plate dimensioned to fit the area in CAD, then had it CNC plasma cut at a buddy's shop.
I clamped it up and cleaned off some of the slag, as well as drilled the holes for speaker mounting, and welded in the weld-nuts:
The fit is good!
I can't remember if this is a pic of welding in the speaker plate, or the deck under the substructure... either way its in the same area:
Here it is, welded in, speaker mounted:
Anyway, I'd call that the end of phase 1.
After operating for a little bit, I noticed the speaker bracket had a LOT of vibration at higher volumes, and it didn't sound great. I added some bracing to the sides of the plate, which helped a little, but I still wasn't getting the performance out of the speakers that I was expecting.
Anyway, I don't know how I've gone through life not knowing about these speaker baffles that are out there.
https://www.amazon.com/050380-Boom-Spea ... er+baffles
It helps seal the speaker in a free-air setup, giving it some air spring, increasing the efficiency and bass.
It seems to work fairly well. I listened to the speaker at low to mid volumes while popping it in and out of the baffle housing and noticed a pretty solid difference.
So this concludes phase 1.5.
Next up, I'm converting the front speakers from 4x6s to 6.5s using the replacement brackets available all over the internet.
https://www.amazon.com/1989-1994-Nissan ... sx+speaker
I'll also be checking/verifying speaker performance and have some baffles for these already on hand. Hopefully everything will be satisfactory after that!
