Originally posted by pmkls2 And now that we are talking all civil like there are a few things you should know. !.
I apologize for insulting you, if any. But I cannot stand people using "I have 10 years experience" or "Certifian Technician" or "a PhD degree" as a bragging tools to show they are right or know more. I follow rules by the book, reliable sources, eyewitness fact or hardcopy effidence. (driving your car is not a realiable sources, because too many environment variance)
Like I said, most of us believe KA24E programming do not use IAT reading as fuel map input. This theory can be broken if you can show a dyno chart, with WB o2 reading (as fuel amount change). Another solution is using scanning tool. Since scanning tool is not available, but this can be easily archieve by using some piggy back system, which read ecu to injectors reading ( and alter, then resend to injector for proper fueling).
Yet, this mod is not worth further reseaching even if it DO alterfuel. Getting better fuel at low-end, doesn't mean you get good fuel at mid-range or top-end. Total fuel management ( stand alone) is only way to go.
Thank you for your offer on the soldered terminal. My fuel system is a mess now, and I can't afford any further mod until I got my fuel management fix. (Working on my the other car - GVR4) But there's 1 thing you can do to help my leaking-real-bad-injector ( just 1. how bad is the leak? I can soak up the whole kitchien towel if I drive it real hard with 5.5psi boost) Any spare 24E top feed lying around?
peace
