SloMoe »
https://forums.nicoclub.com/slomoe-u5234.html
Tue Nov 25, 2003 8:05 am
You said you've replaced every part imaginable, if so then how long ago did you replace the master/slave cylinders? If it was farily recently then I would file a warranty claim with the manufacturer of the part. If you havent changed it then you should have, your car is at least 13 years old, and parts do need to be changed, its part of owning a car. And besides looking at your signature with all those parts you have installed your probably not too easy on that clutch, so that should have been taken into consideration and should have been replaced. Its called maintaining your vehicle, and your going to have to do it to every vehicle you own, unless your wealthy enough to buy a new car everytime something breaks, but there are not many on this board who can, if any.
