The first thing I recommend you do is to convert to S15 CAS/Coil-Packs with a Standalone. The wiring it pretty technical, but I'm sure you can handle it. This will let you do more things with the engine.
Not sure if I told you already, but you will not be able to modify the ECM (such as Nistune) because the ECM, though it is pinned for a NA S15, is actually from a SR16VE, but modified by Autech. So I now have a S15 Power FC. I've ran on 91 octane, 95 octane, 100 octane, and E85 (which is currently what I'm running on).
This engine must run on nothing less than 95 octane with the Autech ECM. You will knock all over the place, even at idle with 91. High compression is no joke. You can still knock pretty bad on 95 if the temperatures are hot enough.
Last thing I could say that you should be pretty happy about is that this engine already has a 272 Intake cam
WITH VTC. You can get a few more HP out of the top end with a 272 exhaust cam with an adjustable cam gear. VTC is makes a HUGE difference across the entire RPM range. I'm talking 15hp difference from 2000-6000RPM. After that, it doesn't make more than 8hp difference, but an aftermarket exhaust cam can bump that up. I don't recommend getting rid of it.
Having a 272 Intake Cam with VTC is very valuable because S14 and S15 SR20DET engines don't have them. If they wanted to get aftermarket cams with longer duration, they would have to give up the VTC function or source an Autech cam, but the odds of finding one are slim to none. People will just say that they can make it up by changing the turbo and tuning it. But, you can do the same exact thing, WITH the 272 cam, and have more fine tuning. Anyway, that's just food for thought. If you become turbo hungry, drop the compression, and turbocharge this engine, having that cam still sets you apart. I satisfy my turbo hunger by just having one NA car and one turbocharged car (New project car; still unveiled
