thanks for the info & help...now ill share
jwrattlesnake
Car: 1982 datsun 4x4 truck
ok heres the deal....truck was skipping at idol...no power would only get up to about 50 to the floor...changed plugs cap rotor new carb and filters cut cat converter...and i didnt have a compression tester couldve solved alot...but it was the head gasket inbetween #2 & #3 cyl...wasnt leaking water or anything....just loosing compression from the gasket...thanks for everyones help....just thought i would post this so if somebody else has these symptoms it might be easier to find out whats wrong with thiers...laters
