Thanks for the Idea EddNog & Venom_Rogue
Orphanedcowboy
Car: ???? Nissan Rogue SL
I removed all the badges off the rear:
I like it much better
EddNog
Car: 2008 Nissan Rogue SL AWD
Sweet!
So the rear Nissan emblem doesn't use two pins to hold it in? If it did, it should leave two holes behind when removed.
If that's the case I'm going to remove my Nissan emblem too!
-Ed
Orphanedcowboy
EddNog wrote:Sweet!
-Ed
I was concerned about that as well, so I bought a roll of 3M emblem tape(grey double backed tape) just in case, I was relieved it didn't have the alignment pins!
I3urn
Car: Nissan Rogue SL AWD
what did you use to take them off? And doesn't it leave some kind of residue? What did you use to clean that? I am planning on to take mine off too!!
Thanks!
Orphanedcowboy
I used
I3urn wrote:what did you use to take them off? And doesn't it leave some kind of residue? What did you use to clean that? I am planning on to take mine off too!!
Thanks!
I used a small screwdriver under the edge of each emblem, take care not to scratch the paint, and lifted them off the vehicle. I then used an industrial box tape, gorilla tape may work, and pulled off the double back tape. After the double back tape was all gone, I used soap and water, then wax to clean up each area.
Venom_Rogue
looks goooooood!
You should remove the wiper too!!!! It would be really clean.
droopy170
Car: 08 Rogue S Indigo Blue
Debadged my suzuki motorcycle; Goo gone(several applications) and an old credit card got all the left over tape off. Fishing line behind the badges to remove them(no scratch potential like a screwdriver).
Droopy
Eikon
Car: 71 240z, 93 Supra TT
Another tip.. use a hair dryer to heat it up a bit... don't leave it forever or you'll hurt the paint, but enough to heat up the glue behind the badges.. they'll peel off much easier then.
Use goo-gone or go to an auto parts store and get some wax and grease remover and that will pull off all the glue residue really easily.
Finally make sure you wax the area nicely after your done and it's all dry and clean. A nice coat of wax will really help the finish stay nice.
Leo2005
Venom_Rogue wrote:looks goooooood!
Remove tail lights and bumper protector as well.
I3urn
Thanks for the tips everybody! I will probably be doing this this weekend! I will post pix when I'm done! Thanks again!
Return to “Rogue Forum”
