frankh21 »
https://forums.nicoclub.com/frankh21-u165169.html
Tue Jul 27, 2010 8:47 pm
I'd like to thank the forum members for all the how to's and FSM's that has helped me with my recent Pathfinder purchase!!
So far I've done the following with your help:
-R/R the transmission fluid and filter
-Changed engine oil/filter
-Changed out the fuel filter
-Recharged the A/C system
-Installed Cabin filter (had to cut out the plastic pieces, but it was actually pretty easy thanks to the walkthrough!!)
-pulled out all the seats and detailed the carpet
Still need to do:
-Flush out coolant (looks pretty easy)
-Spark Plugs (driver side looks like a real pain, anyone have a good method?)
-Rear Differential (tried taking the fill plug out first, based on a members suggestion but no luck, will WD-40 help?)
-Fix rear passenger door lock (won't lock or unlock when either remote or drivers switch is activated)
-Fix front passenger window switch? (window won't go down but will go up)
BTW my car is a 1999.5 Pathfinder 4x2.
Thanks!!
