Fla240sx »
https://forums.nicoclub.com/fla240sx-u71754.html
Sun Oct 28, 2007 3:06 am
no no, c4's are built up VERY strong....... I've seen way too many 350's pop on damn near stock 350's from the 70's..........
u maybe thinking of the 200c, a close relative of the 200-4r... that was used on 6 banger models... most 200-4r's can be found in B bodies or G bodies with v8's or FI v6.....
see the problem with transmissions and saying my buddies 2k dollar one keeps blowing up with X amount of power is this:
most transmission people are scumbags.... he maybe charging you what you think is a lot, so you must be getting a good transmission correct? not always the case.... in fact your typical gearhead wouldn't know what he was looking at inside a transmission anyhow, none the less take it apart and put it back together........ if he could why did he bring it to a shop in the first place? so shady transmission shops have many practices of not putting parts inside that you paid for.........
the 700 and 4l60 are the same thing power wise.. however newer model 4L60's have some updated parts to help with power....... they all share the same sized bands/clutches/converters though........ you can't act like a 700 will hold up to 100 more horsepower then a 4l60 cause thats not the case at all......... they are both equal..... with the one thing the 4L60 has as an advantage is computer controlled....... computers rule..... harder to setup... but once it is, its 10x better....... same reason why most people are switching over to expensive FI setups on their SBC's.... TPI conversions, or just going the LT1-LS1 route..... who wants to dabble with carbs when you have today's technology that just smokes that garbage........ again one thing carbs have going for them is ease of setup... particularily in swap conversions.......
I also stand by my 200-4r is more durable then a 700 comment........ you fix a few little problems and buy a billet converter, they will take very fast ET times
another cool thing I forgot to mention about the 200 is its less rotating mass........ compared to a TH400 or 4L80E..... it is a very noticeable difference....... those transmissions must spin some HEAVY parts... although lighter replacement parts have been made for the cost of an arm and leg.... or 4 digits
believe me, if you ever plan to put your 240sx with a v8 swap on the road... you will surely wish you had overdrive. hell stock at highway cruising speeds I still put over 3k RPM's on my little SOHC KA....... I couldn't imagine doing that to a v8....... and then your not even going to have overdrive! you do know what kind of gear ratio a 240sx has for its rear end stock don't you?
