Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Sat Jun 30, 2007 4:18 pm
If the car will run, you get the engine warm. Then you check voltage from the signal out to the ground. It should be about .6v at idle (about 1v at 1500rpm), if not, it's bad.
Other than that, no, there isn't. Unfortunately, you just can't do a test using continuity.
