OmarM »
https://forums.nicoclub.com/omarm-u34102.html
Sat Jun 24, 2006 9:05 am
Seeing How much I could sell my CA Engine with transmission etc.
Pretty Much complete Rebuild of the motor with receipts.Motor isnt finished yet and is located at PCC Machine Shop in Kissimmee, Fl. 407-933-5889.
THese guys work on anything and everything. Top-notch work that I am paying top dollar for.
Complete Rebuild of Head with 3 angle valve job, new valve stem seals, deck the head, pretty much brand new head.
Block has been honed and bored for 83.5mm CP Pistons on Recertified Rods and Micropolished Crank. New Freeze Plugs, Re-deck the block.
AJUSA Full Gasket Set, TOGA HP Main and Rod Bearings, Brand New Nissan Oil and Water Pump.
Resurfaced flywheel with Spec Stg. 2 Clutch.
Engine Accessories include: S15 Spec-R Model T28BB (not all s15 t28s are alike)Forge Motorsport ActuatorForge Motorsport BOVForge Motorsport Manual Boost controllerBrand New not installed 550cc injectorsZ32 MAF with Apexii FilterZ32 Fuel FilterSSAutochrome Manifold and DumptubeStock Manifold includedMegan Racing Downpipe and TestpipePeak Performance Urethane transmission MountJT Solid Motor Mounts (Beefy)SSAuto Front mount with PipingIMPUL Tuned ECU
This Setup tuned right should net close to 300whp if not more. I suggest some Cams to fully reap the rewards, I might purchase cams not sure yet.
Looking for what I can sell this thing for. And before any lowballers post machine work alone is approaching $900+. Turbo was $700.
So I figure CA18DET motor and transmission run about $1000-1200All the Machine work $900+Turbo $700CP Pistons $500
That right there is close to $3000, so thats probably the least I would take. Let alone theres atleast another $1500 in parts.
Point me in the direction of people who would be interested like MGBs or Datsuns or whomever.
