mattd1979 »
https://forums.nicoclub.com/mattd1979-u21551.html
Thu Mar 23, 2006 11:48 am
Ok. I measured the volts at the connector and A is .010 volts, C is .013v and B is 11.84v. As far as the color of the wires. I had to cut the boot off that covered them and did not find a white wire. I found a green, black with white tracer, and a red. When I measured the resistance of the TPS, I didn't get anything until half way and then at the halfway point it went from 0.0 to 0.00 which seems to be a short. I set the meter to 20k ohms as mentioned.
