testing the vlsd
crazspence
Car: 1993 300ZX Z32
i was told that inorder to see if your VLSD was still properly functioning or not youre suppose to lift up the back and rotate the wheels. and that if your VLSD was still working, you could spin the wheel one way and the other wheel would either, go the same direction, or move in the opposite direction. i forgot which one is it. the VLSD is suppose to be different from a regular LSD. does anyone know which direction it should turn? thanks.
robomatic12
Car: 1990 300ZX TT
crazspence wrote:i was told that inorder to see if your VLSD was still properly functioning or not youre suppose to lift up the back and rotate the wheels. and that if your VLSD was still working, you could spin the wheel one way and the other wheel would either, go the same direction, or move in the opposite direction. i forgot which one is it. the VLSD is suppose to be different from a regular LSD. does anyone know which direction it should turn? thanks.
Boring way:
An open diff they will spin opposite directions and the vlsd/lsd should spin in the same direction.
Fun way:
Rev it up and dump the clutch, get out of the car and see if both wheels left rubber.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
VLSD's don't respond the same way as a CLSD, a VSLD uses viscous pressure generated by a sliping tire to engage the other, it's kinda like a torque convertor, the upside si since there is no friction they don't wear out
CrazedZ32Owner
Car: 91 Z32 TT(no motor), 2008 350Z Nismo, 05 Pontiac Sunfire speed machine!!! :)
Boring way:
Fun way:
i know what im doing tomorow lol
Chattzx
Car: 90 Z32
^don't burn out your clutch
