*Testing*
boost_boy
Just checking to make sure I can still do this as it has been a long time.
boost_boy
Get back to you guys with some pics of what I got going on. Unfortunately, I will not be able to give you the full preview on this puppy. This engine's compression has went from 150psi across the board to 90 psi across the board. Oh well, I'm on vacation so I'll just build another one and replace it (no time to open it up).
Out with old set-up.
And in with the new.
float_6969
Psst! you put the motor in sideways
beans33
Car: 1993 ca18det 240sx
Did I just read Dee has time to work on a motor ? Can't be true. Lol
boost_boy
float_6969 wrote:Psst! you put the motor in sideways
I've accepted this and still was able to move "FORWARD"...get it :lolling:
boost_boy
beans33 wrote:Did I just read Dee has time to work on a motor ? Can't be true. Lol
There is a gracious GOD somewhere in the universe that knows I could use a break. On vacation for the rest of 2012, so it's time to get rid of/sell some stuff, fix some stuff, relax and enjoy my family as well. And btw, it is true ;) .
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
*See's low compression, adds cap full of ATF to each cylinder, places for sale sign on windshield*
boost_boy
"For sale"???? WE are talking rarety-classic stuff here man. This whole car is heavily fabricated, so the low compression crap means nothing here. And besides, I've been wanting to change the motor because surface rust was on the block and some other stuff and the fact that this wasn't the first time this engine has pulled this stunt. Actually, this is the 3rd time it has done this which means I must effectuate the 3 strike rule which simply says "YOU'RE OUT".
float_6969
Dee's got jokes!!!
s13drifter88
I was kidding about the for sale comment lol. My compression was a little low on my CA from the get go so I just rotated my EVC6 knob clockwise a little and viola, low compression fixed haha.
#becauselowcompressionmeansmoreboostfriendlyright?
boost_boy
s13drifter88 wrote:I was kidding about the for sale comment lol. My compression was a little low on my CA from the get go so I just rotated my EVC6 knob clockwise a little and viola, low compression fixed haha.
I knew you were kidding, but I was just going along with the bit ;). This engine is old and the head has given me problems before. Like I stated in previous, this is not the first low compression issue with this particular motor. It doesn't smoke or make mechanical noises, but it does have a slight lopy miss to it. I've been wanting to pulll it and now I have a reason to. I should have it out in about an hour. Later :)
s13drifter88
An hour? D*mn are you taking the time to choke your chicken too? They dont take that long! *Sparks torch*
boost_boy
Sucks to have to take it out, but now I can be nosy. I hate having this kind of spare time :naughty:
mdb4879
Car: 1987 Nissan Pulsar SE (CA18DET)
1990 Nissan 240SX (KA24E)
1995 Acura Integra GSR
s13drifter88 wrote:An hour? D*mn are you taking the time to choke your chicken too? They dont take that long! *Sparks torch*
Obviously you've never worked on a FWD CA. Talk about a PITA, lol. Especially if he wants to pull just the motor and leave the trans. (Coming out the top, I would assume?)
boost_boy
@s13drifter88 *Sarcastic bastard* I'm not that easy to turn-on...lol
I did remove the engine from the top with the transmission attached of course. That would be suicide if I attempted to remove the engine and leave the transmission. If this was was an E-series motor, perhaps. But not with the CA18DET installed in the B12's engine bay. However, I did leave the P/S pump, compressor and removed the alternator prior to removing the block. And also took of the front torque strap bracket because that thing likes to poke holes in condensers and mine is a one-off unit, so I can't afford to damage it.
mdb4879
boost_boy wrote:@s13drifter88 *Sarcastic bastard* I'm not that easy to turn-on...lol
Yeah, you don't seem to get turned on quite as easy as float and TMS do when they get around each other, lol.
I remember I pulled mine from the top without the transmission, but it was a PITA. As I remember I probably had to pull the harmonic balancer to get enough clearance, and I didn't have any accessories on the motor. I remember it took me three days to do my swap. I had to pull a CA16, the CA18 from the donor car, and drop it in the car the CA16 came from. I think that part only took a day and a half, but I did a whole bunch of extra stuff along the way, so it turned into a long three days. Anyways, I think my thing is I just don't like having to pull the axles and drain the transmission, so I just leave it in there. I should probably learn better.
Wow, you kept P/S and A/C? That's what's up! If I ever get to where I can build my monster CA powered Pulsar I'll have to hit you up if I can't figure it out on my own.
Ahhhh, the E-series. What a golden little motor... for anything not performance related that is, lol. Granted I do have a few rare goodies for one if I ever decide to actually build one the way I had intended. It's just so hard to bring myself to ever spend that kind of money on it after seeing how much more a CA can do. And now after having a Honda B-series and seeing it's potential (I know, blasphemy) anything all motor seems pointless other than a Honda (I was planning on a 200hp all motor E16 :chuckle: before I got my CA). Maybe if I ever make money like Rick Nasty (Kyle knows who I'm talking about) I can build all these dream cars I have in mind.
Anyways, my E16 was probably about the easiest thing I've ever worked on. Man, if you guys thought a CA was small you should take a look at an E-series. It'll almost fit in the palm of your hand, lol.
float_6969
TMS and I have an internet bro-mance, so it's all good, lol!
s13drifter88
I love it when you two talk dirty
