Testing procedure on the ignitor?
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Does anyone know the testing procedure with a multimeter on the CA ignitor? If so, what is it and what are the resistance values?
pulsar gtr
Car: NISSAN VEHICLES
PULSAR GTRRafi
c-rad
What section is that in in the manual??? I looked EVERYWHERE.
pulsar gtr
you won't find the exact thing in the S13 manual, this section is taken from the PULSAR MANUAL , but the ignitor is identical in shape and part #.
Your welcome
PULSAR GTRRafi
c-rad
weldinghank sent me something almost identical but it had some different stuff on the pages. Weird. Anyway, I guess I need to get myself a chilton manual....
pulsar gtr
if you need a copy of the pulsar manual, catch me on msn at [email protected] and I will msn it for you, I also have the s13 manual with the ca18det.
PULSAR GTRRafi
NeedCAforS13
Car: CA swapped S13 coupe
chris, I also have a pulsar manual (hard copy) if you need anything
Sean
c-rad
NeedCAforS13 wrote:chris, I also have a pulsar manual (hard copy) if you need anything
Sean
Ok great. My friend is putting his CA in as we speak. It turns over but has no spark. Coils tested fine, so power transistor is next, then CAS, then ECU. We'll see what happens. His harness is kind of a debocle so the answer might be in there including some bad grounding.
WeldingHank
Car: 1989 240sx CA18DET
what i sent you is from the S13 CA18 FSM.
