Q45tech wrote:What really counts is BTU per gallon, as the higher the btu the higher the pressure......................study historicals of gasoline before oxygenates were added , before the EPA required reduced aromatics and allow the thinning of gasoline to allow more from a barrel of oil.Doesn't work with diesel why MPG is superior.
http://www.nafa.org/Template.c...lentsh ... fgecon.htm
In 1995 gasoline was 124,000 BTU per gallon today you are lucky to find 111,000....................magically it lost 10% when we increased number of gallons per oil barrel by 10%
You can also add xylene which is an actuall aromatic added to fuel. My understanding is that it is a really high MON octane, with a high Kj burn off as well, good substitute for power, bad on the enviornment though. Not to mention a gallon of xylene will cost almost $20, unless of coarse you buy it in bulk at contractor supply stores.Another reason why gasoline of today is so low on power is it's mixture with ethanol which is roughly in the 10% range added to all street gas. MTBE was a good source of power until we found out it wasn't as enviornmentally friendly as we thought it was.
What really sucks about todays more modern fuel compared to fuel sold around 20years ago, is it's high volatility to ambient air temprature... Since the fuel of today has a lower BTU, or KiloJoule burn rate it expands and vaporizes faster. So lets say you drive around on a hot summer day that is in the mid 90* F, your engine will make on average 10HP less on AVG, than driving in a mildly 70*F spring day....
Really this hole enviornmentally friendly thing on making fuels cleaner is only making us consume oil faster. Whats worse pumping oil faster out of the ground at an alarming rate, or crossing our fingers that the Ozone is causing this green house effect.
Really engines are so technologically advanced we should go back to when catylitic converters and EGR's were non existant. Then we would have cars producing roughly 60miles per gallon with todays engines. using less gas that we would pump out of the ground. It takes energy to make energy. So the catylitic process through back pressure consumes engine power like a leach, not to mention we are using fuels that are less in energy.....
Sorry I had to ramble..
