skazzi »
https://forums.nicoclub.com/skazzi-u11643.html
Wed Jul 21, 2004 7:13 am
Hey all, probably a few goofy questions. Please forgive me.
Could someone please post the step by step for completing a test of the Ignition Coil? Symptoms in my car match the description for this going bad. I just replaced the Head Temperature Sensor with no change to my startup problems. (was getting code 13 on the ECU). It was suggestions the IC could be the problem?
Also, is it a must to purchase (if ness) a brand new Ignition Coil? My engine has 230k kms on, this part is not usual to go bad, can I take one from a car with lesser Kms and expect it to work?
Furthermore, the AIV (Air Induction? Valve) ... the Cube shaped box very near to the ignition coil. Mine leaks, could I replace this with a used one as well or would it go bad in the yard?
Thank you.
