NISTECH »
https://forums.nicoclub.com/nistech-u7581.html
Thu Jan 22, 2004 12:39 pm
the FPR should not be between the rail and the the fule filter. the FPR should be on the return line side of the rail. but you do take the reading between the fuel filter and the rail. you can do a leak down with it installed. hook it up and turn the key on then shut the key off. the fuel pressure should hold and not drop off to 0. It may drop off a little thats ok but if it just drop s mback down to zero somethings leaking. not nessesarily the injectors could be pump or FPR. you need to pinch off the return or the supplie line ,one at a time till you figure out where the loss is. if you get to the point it still losses pressure when you pinch both the return and the supply off . your leak is in your rail.
