Cjmartz2k »
https://forums.nicoclub.com/cjmartz2k-u65761.html
Sun Sep 06, 2009 1:59 pm
DP, what gap are you running on the plugs?
I've posted this before, but I don't feel like searching for it. s***, I might have to do a write up just so I don't have to type this anymore........
With ignition, electricity acts like running water. It's going to take the path of least resistance. It's going to go somehwere, and the weakest link in even the best, new ignition on an RB is the coil packs. If you coil packs are cracked and the insulation isn't working well, it'll arc there with brand new plugs and small gaps. If your plugs are bad, it'll arc through the coil pack even if the packs are new. If your gap is to big, it'll arc through the pack. If your tune is off, it'll arc though the coil pack. It's all about the weakest link. You might not miss at idle or at low boost, but when you get into higher boost, it'll miss. It's because the mixture in the cylinder is tougher to light off, and you have a weak link.
Other things can go wrong like wiring or a bad ignitor, but those typically cause a hard miss even at idle, just like a completly fouled plug or completly tanked coil.
Keep in mind, one thing can "band aid" another. If you have a "weak" coil pack (insulation isn't the best, but it still puts up a fight to the electricity), and you put brand new plugs in or lower the gap, it might make the miss go away, but you still have a weak coil. Turn up the boost even more, and it'll miss again. Same thing if you have a dirty plug and you put a new coil pack on there. It's all about the weakest link.
One other thing on stock coils vs. splitfires/yellow jacket/aftermarket coils. The only reason they work "better" is because people are replacing old, missing or weak coils with brand new ones. They are the same thing. I have a pile of about 30 coil packs out of everything from a n/a RB20 to a turbo 25 to a RB26. I used to grab random ones out of the bucket when one would go back and throw them on. They are all the same. I run 1.8 bar at over 600hp on stock coils. If you are missing on a stock turbo at 13psi, you don't NEED splitfires, you just need not broken coils. Spend the money if you want, but you're waisting it.
