testing an a/c compressor
jt15833
Car: 95' 240SX
im pretty sure I have everything wired correctly and all fuses/relays work so I want to test the actual compressor. can I just run a wire from 12v on the battery to the connector on the compressor? thanks
Jasong
Yes you can. It will make the clutch engage.
