tested my injectors
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
i tested my fuel injectors today with an ohm meter and here is what i got:
#1 cylinder: 11.8 ohms#2 cylinder: 19.7 ohms#3 cylinder: 11.8 ohms#4 cylinder: 11.9 ohms#5 cylidner: 11.7 ohms#6 cylinder: 11.4 ohms
the only one that is off is #2, but is it enough off to cause any problems? thanks.
aaacomp
Car: Family, church, Computers, Cars
Yes, it is .. Have you ran a balance test on it.. ? Did you recently change any of them.. Seems alot of guys twist the o rings when installing them.. I use petroleum jelly on the o rings when changing push in then put insulator cap on and tighten slowly.
#2 is supposed to be easy to remove with the plenium on ...
aaacomp
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
crazy, fix that Jared! now!
-Dan
