Tested compression before goin KAT...not soo good
lilskyline240
Car: 90 240sx w/ rb30det
my compression came up 152, 150, 153, 160....dropped some oil in the cylinders and the compression came right up...so the rings are goin out....
should i just slap the kit on since i dont notice ANY burning oil or any problems
or put in new rings??
how hard is it to just replace the rings and what would i all have to buy for that??
UltraRed2$0sx
Car: 97 S14
I think that if you add oil when doing a comp test and the compression does come up it suggest that your vavles are opening or lighely open...
I dont know if this is correct or not.
Paul
lilskyline240
no, it means your rings are starting to go....
GEO
Car: 95 240sx KA-T
means you rings are going cause the oil seals the seals, thus naking the comp go up
lilskyline240
since the compression is pretty much teh same throughout, do you think im good to go KAT??
LEMHEAD16
Car: '12 Genesis Coupe
'95 QofDOOM
'56 Chevy pick up
My compression is lower than that and I am running 14psi with no problems. Turbo has been on for almost a year now. I day do it. If the rings go, rebuild.
lilskyline240
what was your compression before you put your turbo on?
i keep hearing the compression number doesnt matter as much as how linear the numbers are
Structure240sx
its better that the numbers are close together +-5psi is a general rule of thumb.
factory spec for rebuild is 149psi
replacing the rings involves a full engine rebuild
GEO
Car: 95 240sx KA-T
^^ hes alive.....
lilskyline240
are there any other factors that can contribute to lower compression numbers?? like oil type or anything??
my gauge is a $20 dollar autozone one if that makes any difference
Kittychubbs
Car: 180sx Ae86 Aw11 and a VIP ^o^
Hey GeoI have the same turbo u have though i have 63 trim
how did u do ur downpipe, i see u have these:IAP Downpipe + Megan racing stainless steel downpipe how much was that total???
and did u still your turbo kit or did someone do it for you??i have my kit i just need downpipe
how hard is it to install it myself, i mean i have sum knowledge but dont wunna mess it up you know, reply please thank you
lilskyline240
why dont u stop thread jackin and use ur own thread
KATwo40
Car: 1993 240sx KA-T
Boost it. I never even checked my compression before going KA-T just over 2 years ago.
Either the engine runs well or it doesn't. Obviously, all the cylinders are worn fairly evenly and you're not experiencing any oil consumption issues, yet. You'll see some consumption when you go F/I, and might even see some smoke now and then when rompin' on it, but I doubt it'll be anything worth worrying about.
lilskyline240
alright, thanks man....im just gunna boost it...and if i start noticing some burning oil....i can pick up a junkyard motor for cheap anyways....gotta love the KA
lilskyline240
went back to test the compression for a second time today this time hooking it up to a battery charger and disconnecting the fuel pump....and the results are MUCH better....180,178,178,180.....so i definitely think that having the battery connected to a charger and disconnecting the fuel makes a bigger difference then we all thought
Modified by lilskyline240 at 6:24 PM 8/2/2006
Chezedik
Car: 1991 Nissan 240sx
Boost it. First, engines are consumable. Forget about having your car forever. You won't live forever, and neither will your car. But it has one advantage over you, parts are a lot cheaper.2) Compression is uniform, and it doesn't burn oil. Most manufacturers are quick to point out now that it is more important that compression be uniform, than to a certain spec. I can almost promise you it will be higher with new rings, but I say don't worry about it until it is a problem. Just be sure to turbo wisely.
Kittychubbs
ahhhhh ur so mean!!!! well u know i though he could help. who are u anyways huhuh NICO founder??
wild_maxx
Car: 90 TT pearl yellow z32
Kittychubbs wrote:ahhhhh ur so mean!!!! well u know i though he could help. who are u anyways huhuh NICO founder??
its kinda a general rule of forums... don't get in someone else's thread and start asking your own unrelated questions in their thread. Start your own thread or just PM/Email him if you have some question.
rotorimp
Car: 02 Xterra, 60 IH Metro
Are you doing the compression check when the motor is hot or cold? Generally you want to do the check with the motor warm, tb wide open and the fuel and spark disconnected. Good luke with the Turbo kit.
hannibal
Car: Red Line to Glenmont
Warm it up. TB open and disconnect fuel by pulling fuse for pump. plugs will obviously be removed so there is no spark
Procedure is found on page EM-8 of the FSM...
lilskyline240
i retested it last nite and it came out 180 on every cylinder....the only diff this time was i disconnected fuel and had a battery charger on it
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
HA. did a compresion test on mine today....all cylinders blew 0!!!! CAN I SAY BENT VALVES!!!! I'm going to need a new head.
lilskyline240
i find it hard that u blew a 0 and ur car is still driveable
WI_S14_Goldie
lilskyline240 wrote:i find it hard that u blew a 0 and ur car is still driveable
DRIVEABLE!!? Who said it was driveable? Its in my garage, i couldn't get top dead center while installing some cams.
PapaSmurf2k3
Site Admin
WI_S14_Goldie wrote:DRIVEABLE!!? Who said it was driveable? Its in my garage, i couldn't get top dead center while installing some cams.
haha, ive been there, there is no worse noise then the sound of a motor with bad valves doing a compression test with 0 compression (its just a straight starter whine)
WI_S14_Goldie
PapaSmurf2k3 wrote:haha, ive been there, there is no worse noise then the sound of a motor with bad valves doing a compression test with 0 compression (its just a straight starter whine)
HAha. Yep thats exactly how it sounds! i was so pissed off at myself when i found out i had bent valves. what did u do with urs?? new head? u noe any places that sell built heads (port and polish)??
GEO
Car: 95 240sx KA-T
Kittychubbs wrote:Hey GeoI have the same turbo u have though i have 63 trim
Me and structure installed the kit in 2 days... Its not hard.. Just take your time!
Downpipe and Sr downpipe was included int eh kit, so I have no idea what they cost.
