Test1
PBfrEAk
Car: '00 Frontier (Newb) '92 Maxima (Daily), '93 Max (Donor), '91 Max (Project) '77 F-150 (Funmobile)
PBfrEAk
is there somthing im doing wrong here...well i know there is but i need to know what...im trying to do the HTML formatting for an image but i cant remember what it is...isnt it [img][/img] or somthing like that? i was just messing around with the emoticons
thanks Cody
Red coupe
Car: 92 Nissan 240sx Coupe
you got it but you need the actual file name aswell...for instance http://ad.nicoclub.com/banners/enjukusmall.jpg...the way you did it you only had up to the http://ad.nicoclub.com/, with no actual file nameso it would be [img]http://ad.nicoclub.com/banners/enjukusmall.jpg[ / img ]
PBfrEAk
so like this....
PBfrEAk
crap...ok this is not working...im being too dumb....ok you said you have to put in the file name....does that go for smiley's too? ok i got them from here... http://www.dodgeintrepid.net/f...id=25# and i was trying to get them to work...but obviously im not doing it right
i tryed just doing it like this [img][/img] and in between i would put what ever like :lickface: <== the 1st one on that page (for example) and i also tried putting the url in it too (although i figured THAT wouldnt work...) and it didnt ....so idk what im doing wrong here....am i just being thick headed? am i missing somthing? more than likely yes lol
Rex
Car: None
It needs to be a standard image name .jpg, .gif, .bmp and the like.
FWIW, I've never had any luck linking smiley's from other forums even if they had the right naming scheme.
Rex
Car: None
We'll see if this works
Rex
Car: None
You need the actual file name, right click the image, select properties and then you can get the url of the image from that.
PBfrEAk
i hope this works....
PBfrEAk
YESS!!!!
thanks alot you really helped out.
Red coupe
would have been alot funnier if I got that in before you got it figured out...Now you see why they made rex and admin
PBfrEAk
Yes it would have lol but yea i can definatly see why...but thanks to you for trying.
Return to “Test Forum”
