test topic
05TurboS2K
Car: 05 Honda S2000 Turbo
On a budget, my best friend and I work 2 jobs to afford our racing. I'm a proud TurboS2000 owner but new to the 240. Had a fairlady Z TT from Europe that I loved to death but its gone now.
TO buisness: I need to know the best car for the money to select to build an all out track car. We plan on stripping and stitch welding the entire car, glass will be removed...everything. I'm decent with turbo work, except im not a tuner. Other then that I understand the turbo world fairly well. I can read a turbo map to say the least. Heres what I need to know, BANG FOR THE BUCK PERFORMANCE. We'd like a turbo motor and to pump the boost up to near the limit of the stock internals HP rating.
Please reply only the stuff you know for sure.Best things to start with:
Body: Motor: (assuming a SR20DET is our motor right?....if so how many psi etc.)Suspension: (expect a cheap coilover kit 3way adjustable min)Setup: spring rates/ toe/ camber/caster/ compression/rebound etc.ETC.
Thank you much in advance.-Greg
05TurboS2K
If you have a lot of info feel free to email [email protected]
Thx
