test
virus77
Car: 95 S14, 71 240z, 97 e320
Alright I blew my motor recently so im parting everything that is still usable. Email me at [email protected] or post here. All parts are from a 95 ka24de and are located in S. Cali.
Stock s14 rear diff, good condition = $80.00
AC electric oil pressure (used)$25.00 and oil temperature (new)$35.00 comes with wiring harness and sensors.http://www.rspistons.com/images/100.jpg
OBD-II scanner. It uses your OBD-II port and a palm handheld to monitor thing like timing, rpm, load, coolant temp, etc. also has an advanved dyno prgram that can be used to see if more horsepower is being made with changes to the tune. It connects with a special cable that is a obd-II port on one side and a palm plug on the other. Here is a link to the software and product. It sells for $230.00 new. Im selling it with a color palm for $180.00 (palm has a hairline crack on back, doesnt effect it at all). IT ALSO RESETS AND CHECKS THE CAR FOR CODES (CEL)
Here is a link to the website: http://www.auterraweb.com/scantools.html
http://www.rspistons.com/images/76.jpgh ... ges/80.jpg
TURBO PARTS
t3/t04e 50 trim wheel in .60 a/r compressor housing - stage 3 wheel in .63 a/r turbine w/ 360 degree bearing. Internal wastegate at 7 psi used for around 11k miles, has no shaft play whatsover. = $400.00
The pics show no wastegate on the turbo because I left it attached to the dpipe because it is easier to unbolt it like that. I realized the pictures are a little decieving from looking at it so im posting this. Its a 5 bolt wastegate housing that attaches to the turbo and a 3 bolt exit for a downpipe to attach to. http://www.rspistons.com/images/37.jpgh ... ges/40.jpg
t25 turbo from redtop sr20det = $180.00 I upgraded to a S15 t28 on the SR motor before it ever went in. The turbo actually looks to be in very good condition, no shaft play whatsover and it spins very frelly, no oil in the turbine either. My motor looked to be very low millage so the turbo should be aswell, ill get pics up later. does not include elbows/turbo outlet or lines
t25 turbo factory turbine outlet = $15.00
3 arias 8.8 cr .020 over piston with wrist pins. You need one new piston and new rings. = $150.00
http://www.rspistons.com/images/41.jpg
KA24DE and SR20DET PARTS
ACT Clutch XTSS still has allot of life left in it. Comes with flywheel so its doesnt need to be resurfaced. You need a generic alighment tool from the auto parts store to install. $200.00
http://www.rspistons.com/images/26.jpgh ... ges/28.jpg
SR20DET AC Compressor = $30.00
sr20det REDTOP ac bracket = $25.00
KA24de AC Compressor = $40.00
KA24DE starter $50.00
http://www.rspistons.com/images/29.jpgh ... ges/30.jpg
KA24DE intake manifold with throttle body and all sensors, no injectors = $40.00
http://www.rspistons.com/images/33.jpgh ... ges/54.jpg
KA24DE distributor = $20.00
http://www.rspistons.com/images/43.jpg
KA24DE ngk plug wires = $30.00
KA24DE power steering pump = $30.00
http://www.rspistons.com/images/49.jpg
KA24DE alternator = $60.00
http://www.rspistons.com/images/55.jpg
KA24DE water pump (less than 3k miles) = $40.00(top right of picture)http://www.rspistons.com/images/43.jpg
KA24DE oil pump with complete front cover(less than 3k miles) = $80.00
http://www.rspistons.com/images/50.jpgh ... ges/51.jpg
KA24DE oil pickup = $5.00
http://www.rspistons.com/images/52.jpg
KA24DE real main seal with cover = $5.00
KA24DE timing chain, tensioner, guides (less thank 3k miles) = $30.00
http://www.rspistons.com/images/53.jpg
KA24DE 91' cams, very good condition = $75.00
http://www.rspistons.com/images/46.jpg
sr20 370cc injectors (I used these so they guaranteed work) = $100.00
stock ka24de injectors (I used these so they guaranteed work) = $30.00
s14 MAFS = $30.00
KA24DE factory exhaust manifold = $20.00
KA24DE stock airbox with intake piping and drop in K&N filter = $20.00
KA24DE charcoal canister = $10.00
KA24DE knock sensor (has small crack in it but still works) = $10.00
95-96 stock rear taillights, good condition, all three pieces with nissan badge. = $60.00
Modified by virus77 at 12:27 AM 6/14/2005
Modified by virus77 at 12:29 AM 6/14/2005
Return to “Test Forum”
