Roots type build more boost because of back pressure yes, but that's not a good thing. No back pressure and a smaller pulley or bigger charger will make far more power more efficiently.joe603 wrote:
This depends. Not all FI apps are equal...
Supercharged engines need some back-pressure to build substantial boost (roots type systems are affected the most). Therefore, headers and test pipes may actually hinder performance. Now a turbo is different. It needs a wide-open exhaust to perform well.
So headers don't hinder performance per se, they hinder the amount of boost a SC can make at any particular rpm. This is the main reason roots blowers are huge, because they need to be in order to move enough air to generate boost on a motor that is functioning at peak efficiency.
More flow in/out is free hp. This is not the same with a centrifugal type or turbo since they actually compress the air.
The key is to have a motor that can move the highest amount of air in/out of the motor across the rpm band, then figure what type of power adder will be the best. I say across the rpm band because some headers may give you more peak power, but fail where we actually need the power the most. But peak numbers are what sell parts...just be leery when it comes to high hp claims for a set of headers or a cat back.
WD
