I don't see how testpipes will cause voiding a warranty ordinarily if going for say, an oil change or air filter replacement. However, while under warranty, if anything goes wrong with the engine, and the test pipe is seen---warranty is voided---just confirmed this with my dealership. I am told that to work on the engine, owner will need to swap out the test pipe before taking the car to dealer for service. Again, the idea of test pipes maybe similar to the idea of cold air intakes, plenum, and spacers which we once feared would void the warranties of our cars. We all know now that this is not the case---I have these mods installed on my car and the car runs great.
And so it raises the question, why is a test pipe as a modification, any more dangerous than a cold air intake, spacer of catback exhaust, which all do alter the manufacturers original performance setting for the car, and which all have been shown to be harmless on our cars?
Here is a website with installation
http://forums.evolutionm.net/s...14931
The CEL fix seems to be in ever growing acceptance. Other than the smell of the exhaust and possibly slightly worse gas mileage, I don't beleive a test pipe affects an engine that badly or causes it to run badly---just confirmed this from my dealership--test pipe just allows for freer flowing gases which causes our cars to run a little more rich than normal (reduction in MPG). So, with spacers, cold air intakes, and Mrevv installed, which causes a car to run leaner, I think a test pipe, and a cat back exahaust, and possibly a header, retards or reverses the leanness from the intake portion, slightly, by running richer, which in essence brings the engine back to a possible state of balance. It maybe a good idea, if one wants to go NA to do the whole install in intake (Cold Air intake, spacer, mrevv, etc) and exhaust (headers, test pipes, cat back exhaust), so that they are balanced out, as it relates to the rich-lean Air Fuel mixture. I can see how re-tuning a car with this set up is a good idea.
I also found out that test pipse do reduce torque below 3500RPM or at the low end, but increase horsepower at the top end. I understand our cats cause some back pressure which does help with increased low end torque.
I beleive trucks spew out more dirt than cars becasue they use diesel.
Yes, the ECU will throw the inevidable PO420, PO430 codes, but then, one is advised to reset the ECU with the hand computer or by disconnecting the battery.
Gas powered cars will never provide clean environments---it is just a hoax. Diesel trains, ship liners, and 18-wheeler trucks, spew out more dirt than a single or a street of cars would ever do with test pipes.
I stand corrected.
Modified by Jacko3 at 1:55 PM 9/10/2008
Modified by Jacko3 at 1:59 PM 9/10/2008
