Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Sun Sep 14, 2008 7:42 am
I recently installed my Strup Testpipes on my car on Saturday evening. I must say that test pipes produce a most delightful and exhiliarating sound you could ever have in a car--makes you drive the car harder so that you can hear the sound.
I also noticed that the car now revs up a little faster. Of course, you will hear some little chatter underneath the car---I think that is normal.
However, as you drive, you get to smell the exhauat in small whiffs, especially when you decelerate, and especially if you drive with your windows down. I am not sure if most Gs can get around this issue completely. Perhaps overtime, the exhaust smell will recede. But this wouldn't deter any die-hard G-35 enthusiast, at all. Generally, when going fast, you don't smell anything at all.
I also noticed that gas mileage has dropped by a bit, especially with the gas being blended with ethanol. It would appear that gas mileage is worse at relatively lower speeds than at relatively high speeds (I am not yet sure about this as I am still studying this phenomenon). what is most important here is that there is a drop in gas mileage. Perhaps, tuning the car to lean it out a little, would be a good idea.
There is indeed a gain in horsepower that you can feel. This is no joke at all. Ratio of horsepower gain to cost of test pipes is perhaps the most I have seen so far. Perhaps the design of the test pipe maybe a factor here---Strup is known for making excellent headers and test pipes.
The drop in torque at low RMPs as i had expected, appeared very limited and in some cases insignificant. Over 3000 RPM, the horsepower gains moved the car quite effortlessly, that it was easy to go over the speed limit without knowing it---it began to bring to mind in its infancy, the effect of a power adder like a turbo or supercharger would have on driving behavior. Judging by this effect, I am reconsidering whether to get a power adder at all, as I can see that a power adder will consume gas (poor MPG), and cause the to go faster and thus, lead to potentially more traffic tickets (just an observation, muse, and evaluation).
Again, the cats were heavy---another weight saving on the G. When the test pipes were installed, the CEL did not come on at all. Of course the test pipes was installed with a CEL Fix or a spark plug anti-foulers. I drove all day and the CEL never came on at all. However, I went to the movies with GF and on our way home, the CEL came on. This morning, I disconnected the negative battery terminal for over 5 minutes and reconnected it back, and the CEL light was off. However, I went to Autozone to check the code and it said P0420--we all know what that means.
I have no idea if the CEL will come back on. But I do know it is worth waiting to see and hopefully report back to you all on the consistency with which it comes back on or if it stays off for a long time. Although, I did notice that when the CEL came on, the gas mileage became worse and terrible. So, I would advice anyone to get that CEL removed as soon as possible, and not to drive for extended periods of time with the CEL.
Another issue with the test pipes is that there is a droning noise when you brake with the clutch---this is annoying and can give a headache. The way i battle this deone is to drive at lower speeds with higher gears. For example, I can go 40 miles an hour in 4th gear instead of the usual 3rd gear i used to use. I can now go 55 miles an hour in 5th gear instead of the 4th gear as i used to---this seems to reduce the droning effect. But the temptation to gun the car is there.
But most of all, I cannot begin to tell anyone or even describe to you how beautiful the sound of a G-35 Coupe can be when you are WOT with a test pipe----truely remarkable. Of course, the sound will depend on the type of catback exhaust you have---I have the Stillen TD Catback Exahust, and it is truely a sound to behold when I gun that car.
So, the real question is, is it worth it to have a test pipe? The answer depends on if you are a tree hugger or not, if you love loud sounds or not, if you care about gas mileage and its cost or not, if you are thrilled by a real sports car sound or not, if you can handle droning sounds or not, if you can remove the CEL readily or not, etc.
There is no straight answer to this test pipe issue. All I know is that I am enjoying it as a part of my modification deal. However, I know someday and somehow, i will remove the test pipe once I begin to experience diminishing utility or returns or if it becomes more trouble than it is worth in the future. For now, I have no CEL light and the car drives like a dream.
Most of all, i would advice that you get the right tools to get the job done. The 02 sensors can get stuck in the cats. If you can't get the tools, let a good mechanic help you out.
I hope to post the Stiillen Exhaust sound once i re-learn how to use my camcorders. I don't know why i am even in the 21st century to begin with .
I forgot to add that my car is a 2007 G-35 Coupe 6MT RAS NAV.
Modified by Jacko3 at 10:55 AM 9/14/2008
Modified by Jacko3 at 1:43 PM 9/14/2008
