my obx header has lasted me just fine. testpipe could free up some restriction but on an n/a motor it wouldnt be noticeable, except being annoyingly loud.Wc240 wrote:good quality headers. no obx. lol at a testpipe gaining you power
Not sure of your setup but because your asking headers or test pipe I assume you have a N/A motor...Dazzla wrote:So i've currently got a apexi n1, and a hi-flow cat. I'm looking at gaining the few extra hp, and most importantly more sound lol. I'm thinking that the test pipe wont be much different then my hi-flow cat?
buy headers or a test pipe? what do you guys think? which headers are good? lol
having back pressure is not beneficial to power...RCA wrote:Not sure of your setup but because your asking headers or test pipe I assume you have a N/A motor...
Headers will add a few (4-5hp) at best. As for the test pipe, experiments have shown that adding a test pipe to a stock N/A vehicle will most likely reduce back pressure and you will loose power. Not only that, you would also be polluting the environment with NOx and other nasty things that would in most cases be absorbed by your cat converter. Stick with just headers so at least this way you can pass emissions.
Edit:My car with headers and test pipe = STUPID loud and still slowhttp://www.youtube.com/watch?v=7WxEwsCKX9w
Your car sounds awesome lolRCA wrote:Not sure of your setup but because your asking headers or test pipe I assume you have a N/A motor...
you wont feel anything from a test pipe unless you have a fairly clogged cat.... you'd be surprised how good factory cats flow....Dazzla wrote:Your car sounds awesome lol
I think ill pickup a test pipe and see how that feels as test pipes are cheaper and easier to find then decent headers
http://www.uucmotorwerks.com/html_product/sue462/backpressuretorquemyth.htm wrote:Getting back to the discussion, the reason that exhaust valves burn is because the engine is burning lean. Normal engines will tolerate lean burning for a little bit, but not for sustained periods of time. The reason why the engine is burning lean to begin with is that the reduction in backpressure is causing more air to be drawn into the combustion chamber than before. Earlier cars (and motorcycles) with carburetion often could not adjust because of the way that backpressure caused air to flow backwards through the carburetor after the air already got loaded down with fuel, and caused the air to receive a second load of fuel. While a bad design, it was nonetheless used in a lot of vehicles. Once these vehicles received performance mods that reduced backpressure, they no longer had that double-loading effect, and then tended to burn valves because of the resulting over-lean condition. This, incidentally, also provides a basis for the "torque increase" seen if backpressure is maintained. As the fuel/air mixture becomes leaner, the resultant combustion will produce progressively less and less of the force needed to produce torque.
Not sure where you got your info from but I have seen the results dynoed that prove otherwise.TheRealNap0le0n wrote:having back pressure is not beneficial to
Just a test-pipe and it will become louder.Dazzla wrote:Lol test pipe sounds really good to me. I want my car to be loud lol the only question that remains is will a test pipe be louder then a hi-flow cat?
You confuse me, 4 months ago you started a thread to find a subtle exhaust. Now you don't care as long as its loud. zerothread?id=450376Good luck.Dazzla wrote: I want my car to be loud
Hey man, remember, your car and mine are exact twins, and I have a test pipe on my 3" Blitz Nur Spec R exhaust. It makes it sound very throaty, and after installing it, the car felt much much smoother, and it seems to move very fast compared to before when I just take my foot off the clutch in gear 1.Dazzla wrote:Your car sounds awesome lol
Oh hell yes SON. After installing mine, it definitely got a s*** load louder in both idling, and when accelerating (huge loudness factor in acceleration).Dazzla wrote:Lol test pipe sounds really good to me. I want my car to be loud lol the only question that remains is will a test pipe be louder then a hi-flow cat?
Oh man, please, don't compare your KA24E to an S14's KA24DE with a way better stock cam setup. . . My S14 sounds like a muscle car with a test pipe. I really need to take a video to show how my car sounds, you guys would s*** bricks.RustspecS13 wrote:Screw putting in a test pipe. That's the worst thing you can do. I know your going for volume but it changes the tone even more. It sounds like a ricey honda bees and resonating and all.
It was the worst change I did to my sohc. I wish I could have still used the factory cat because it drove so much better. Sounded better and it didn't annoy me or destroy your hearing at 3K on the highway.
If you really want loud don't be a puss. Get 4in header back.
~Alex
Screw the headers, it will make your car sound like crap, and on top of all that, the HP gain is peanuts for such an expensive part. Not worth it at all.
By the way, I have a stainless steel circuit sport test pipe that I bought from PDM racing. It came up to $78 after everything , and it's great, no bungs, just pure emptiness.
how is backpressure good at all.... its a force that prevents exhaust gasses from coming out the tail... any back pressure is cause some exhaust gasses to stay in the combustion chamber... exhaust gasses which are not combustible aka make no powerRCA wrote:Not sure where you got your info from but I have seen the results dynoed that prove otherwise.
I know it was a little expensive, but I don't trust s*** from Ebay. Ever since a friend tried to buy a respirator off of ebay, and got rocks in the box, I just can't risk it.TheRealNap0le0n wrote:how's it feel to get a** raped for $80 for a pipe that costs $15 on ebay..... its just a pipe.....
i hear that... i ride a sport bike and a friend asked me to order him a helmet from egay.... he gave me the link and everything... said it was an ICON brand helmet...Jagstang wrote:
Plus, besides Ebay, the price I bought it for was great compared to s*** on craigslist, and legitimate parts site etc.
... more mis-information. the changes in the exhaust affect the exhaust pulse tuning.... moving the powerband up.... BP is not goodInitial_R90 wrote:headers? i didnt know the KA was a v-6 ,
anyways
test pipes and headers gonna make your car scream you will gain top end but lose alot of low end with no BPn/a needs BP turbo cars need none
my 350 with test's y pipe and JIC single sounded amazing and highway pulls were fun but digs were not the greatest didnt get power till after like 4k
I know what you mean my s14 sounds pretty rumbly as it is, it sounds more like a Subaru WRX then a raspy 2 liter lol. Post up a video. I'll probably go with a test pipe too. Probably the mild steel one as I don't care about how it looks versus stainless steel lolJagstang wrote:
By the way, I have a stainless steel circuit sport test pipe that I bought from PDM racing. It came up to $78 after everything, and it's great, no bungs, just pure emptiness.
Modified by Jagstang at 3:03 PM 1/22/2010
how is this miss infomation when I said you gain top end and lose low endTheRealNap0le0n wrote:... more mis-information. the changes in the exhaust affect the exhaust pulse tuning.... moving the powerband up.... BP is not good
you posted a link that supports my point exactly...Initial_R90 wrote:who are you again..
http://auto.howstuffworks.com/question172.htm
pretty much BP from a stock manifold is no good dosent say anything about muffler or test pipe
have you ever driven a car with stright pipes? you step on the gas the rpm's go up but your car dosent move untill higher rpm's
I drove home my ls1 s13 from FLA to NJ on open headers and let me tell you the car didnt move untill i hooked up the rest of it up
Finally someone gets what im sayin...Space Monkey wrote:How many times is this going to be debated?
TheRealNapOleon is correct in saying that any back pressure is BAD and REDUCES power. Also note he states that you need to TUNE your engine for appropriate modifications for it to work or the power-band will be ridiculous.
In a twisted way...the back pressure is "good" as it causes the power-band to stay in spec while keeping a quiet vehicle. But it is still BAD because it is still robbing you of HP and Torque!
For this reason, when you get a new 3" cat back and a hi flow exhaust, with an intake and maybe some new stage 2 cams you will notice some extra power but not as much as if you got your car tuned to use these parts to their potential.
