Jacko3 »
https://forums.nicoclub.com/jacko3-u85814.html
Fri Nov 14, 2008 11:10 pm
I have also heard of some people passing emissions with test pipes---actually met an 04 350z owner who passed emissions with test pipes. That is the point---how do you add test pipes without leaning out the car or without piggy back ECU maps?
I heard that 03 and 04 coupes can pass emissions a lot easier than newer models. So, is this car or G you saw an 03/04? Did it have a piggy back ECU map? Seems like the ECUs are differently coded for each passing year of the same auto model. Mine is an 07 coupe G-35 and I have that trick you talked about---spark plug anti-foulers. so, i wouldn't give many hope that they could pass emmissions with test pipes, while knowing fully well that all our ECUs aren't exactly the same. What do you think?
Modified by Jacko3 at 1:20 AM 11/15/2008
