Test Drive soon! 2004 G35 - what to watch for
kmaot
Hello. I have come from a 93 twin turbo RX7 and 2000 BMW 323i. I am looking to buy a 2004 coupe with about 24K miles on it.
What should I look for? I will drive both a std and automatic to test them both. To be honest, I drove the Nissan Z and found the clutch hard to take. I assume the Infiniti will be the same?
Does anyone have pros/cons about std vs auto as well as tips re a test drive? ie common problems, noises, etc.
Thanks in advanceK
G_whizz
Car: 2010 G37 Coupe Sport
Welcome to Nico ...that year has the Brembo brakes. Great for performance, bad for wear!
Check the brakes!!!
Also, check the sticky thread in the forum here near the top called TSB specifications. That will help you as well!
Tahoemofo
Car: 2004 Infiniti G35 Coupe
I purchased a used 2004 about two weeks ago. This car has ~23000 miles. In review of the service hsitory, the brakes were all replaced about 1000 miles ago. I would check the brakes - as others have suggested. The only other item was an issue with the door trim that was replaced. Good luck and enjoy!
