Hi folks,
In search of my future Q test drove today another candidate and want to ask you if it's worth to buy.
It's 94 Q45 std (+TCS, +heated seats), 95600 miles, black/black.
This is what I found so far. Some terms I use may sound funny since I don't know exact translation and am not American so please bear with my language.
Full report with photos will be available at
http://www.petrovs.com/carbuyi...k.htm It takes some time to upload pics.
The seller sais car had light rear end collision (straight bumper hit). Only bumper was damaged and it was replaced.
It has 17" Cagar rims that says nothing to me. It's, probably, cheapos, Q looks good with them though. I guess that is the reason why they were put. Almost new Z-rated Bridgestone Potenza on those rims, but... rear left tire is Goodyear Eagle, at least with the same specs. Rotors visually looked ok.
Black leather interior in decent shape. Leather is moderately worn but no significant scratches and cuts. Cabin is clean but not perfect. Tint is awful: bubbles and wrinkles. Needs to be redone.
Exterior is not perfect either. Door's edges have small dents and scratches. Things are really bad in the front. Hood has a lot of dings and couple of matte spots on the top. I'd repaint hood and bumper that has scratch on the right side.
I'm not a mechanic and not familiar with Q engines but some things under the hood looked suspicious. It looks that one of three visible pipes (exhaust collector?) is covered with oil or some dark scale. There was light smell of burning oil after highway test drive.The battery is 700CCA, brand new.Radiator's fan has cracks, needs to be replaced. There is some gome on the two central pipes of the cover. Belts look good and feel tight.
Test drive
Noise behind the rear seat, I guess it's fuel pump on the way out. Check Engine light (not the engine pictogram itself but bar above) came on after warming up.Slight steering wheel vibartion at highway speeds that is more noticeable if you apply brakes.I didn't drive Qs too much but this one looked like having some problems with performance. Why do i think so? At 70mph I floored it, it dropped on second gear and din't accelerate much. I barely overtook a minivan going 85mph. Acceleration was very slow I think. Another time, entering on ramp (at wot) it was going good up to 60-70mph and then suddenly went up to 4h gear and stopped sharp acceleration, tacho dropped from ~6.5K to ~2K.
I quoted some numbers to seller:- fuel pump: $500- tires match: $150- under plenum cleaning, resealing, changing hoses: $800-1200- front end repair (source of vibration): $600 - 800- check engine light (O2 sensor, injectors?): $100 - 1000?- radiator fan: $50- paint work: $300-400- re-tint: $200
I'm gonna take it to mechanic before I buy it but given all that found is this car worth $5000 (the price I would buy it)?Asking price is 7500 and KBB private party 5860.
Thanks!
