Terrible noise when turning the Steering wheel
annunziato39
Car: 1990 240 (auto) sold 1992 240 260,000+ miles (rip) 1991 240 (sold) 2007 Infiniti G35 sport 6-speed (Current)
I have a 1991 240sx. When I turn the wheel at low speed (like pulling into a parking spot) There is a loud whine. I think its the power steering, but i'm not sure if it is the whole unit or maybe just some lines. Any help would be greatly appreciated. thanks guys.
nissanman04
Car: '90 240SX, '95 Subaru Legacy
Your pump may be on its way out. check fluid level as well.
Kittychubbs
Car: 180sx Ae86 Aw11 and a VIP ^o^
must be almost empty on the fluid.mine does it too. once i add P.S fluid it goes awaybut we gotta start saving for a pump.
Bronze MFP
Car: 1987 Nissan 300ZX w/digital dash radness
it's really hard to kill the ps pumps in our cars. even the FSM says that running them low on fluid shouldnt damage them. mine ran low for a month or so until i got a replacement for the hose that was leaking. once it wasnt running dry anymore it shut up and worked fine afterwards. check for leaks where the hoses connect or in the rubber hoses themselves, make sure the resivoir is filled properly and the noise should go away. if not then you may need a new pump.
annunziato39
Thanks everyone, i'll keep you posted on what i do.
annunziato39
Well it looks like I have a small leak, but as for now, i added some fluid and it runs like new. Thanks for the help guys.
nissanman04
