You mean PCV (positive crankcase ventilation) valve right?jpsc wrote:I had similar problems - then fail CA smog check.After about $1000 diagnostic and fixing at the dealership - it turns out to be a PVC valve needs to be replace.
So change your 240SX PVC and put in a new Oxygen sensor.
