ECU: Mode 1 when first turn on both lights are off. RPM to 2000 and the green light comes on and stays on for 18s and then off for 3s and then on for 18s repeating. Mode 3 code 55 everything is OK.
** WHAT does this mean as not in book.
CODE 2 Mixture ration book says if RED and Green blink simultaneously. Mine at 2000 RPM both come on and stay on. No blinking.
Plugs are all black with burnt carbon (none are oily, or tan) Distributor: Both rotor and HT lugs had corrosion (Have just cleaned up for now but will need all 3 replaced.
Have disconnected heater - no difference, restricted top radiator hose to 20% flow - no difference. Can't see any water moving in radiator after driving for 30 mins in 15 degrees c - water at 30 degrees c in radiator and temp gauge at 1/4. It appears I've got an air cooled terrano
Please help, any suggestions.
1) Can the ECU cause this
2) My past tells me that only the Stat can do it. Mine is not opening as the water does not get hot enough. I removed heater hose after a long drive, it was hot but did't burn me.
